Orion-Tr Smart doesn’t charge properly when solar is active
Hello everyone,
I have a problem with my Victron Orion-Tr Smart DC-DC charger in my Fiat Ducato with a smart alternator (Euro 6).
My setup:
  • Fiat Ducato Euro 6 with smart alternator
  • Victron Orion-Tr Smart 12/12-30A
  • 1 × Victron Lithium Battery Smart 160 Ah (LiFePO4)
  • Victron MultiPlus 12/1600/70-16
  • Cerbo GX with DVCC enabled
  • VE.Bus BMS
  • 2 × 200 W Renogy solar panels with Victron MPPT charge controllers
  • Orion connected to the vehicle’s D+ signal via the remote terminal
The problem:
While driving, the Orion often stays in Float mode (13.5 V), even though the leisure battery is not fully charged yet—for example, when it’s at 93% SOC.
At the same time, the solar panels are generating power and keeping the battery voltage at around 13.4–13.5 V.
I suspect the solar charge controllers are keeping the battery voltage high enough to prevent the Orion from starting a new Bulk charging cycle.
The Fiat Ducato’s smart alternator also reduces its voltage depending on the operating conditions. At times, I’ve measured only 11.7 V at the Orion’s input. I haven’t yet checked whether the voltage is equally low directly at the starter battery.
Current Orion settings:
  • Absorption voltage: 14.2 V
  • Float voltage: 13.5 V
  • Re-bulk voltage offset: 0.1 V
  • Fixed absorption time: 2 hours
  • Engine shutdown detection: enabled
  • Alternator type: Smart alternator
  • Start voltage: 14.0 V
  • Delayed start voltage: 13.3 V
  • Shutdown voltage: 13.1 V
My questions:
  1. Is this behaviour known when using the Orion-Tr Smart together with solar charge controllers?
  2. What settings would make sense to ensure the Orion charges reliably while driving, even when the solar system is already producing a relatively high battery voltage?
  3. Should engine shutdown detection remain enabled when a D+ signal is present, or is there a better configuration for the Fiat Ducato’s smart alternator?
  4. Would switching to the new Orion XS 50A solve or at least improve the problem, particularly through the VE.Direct connection and DVCC control via the Cerbo GX?
My aim is for the Orion to charge the leisure battery reliably while driving whenever charging is needed—regardless of whether solar power is being generated at the same time. And, of course, without unnecessarily discharging the starter battery.
Has anyone had similar experiences with a Fiat Ducato Euro 6 and a combination of Orion and solar?
Thanks in advance for your help and experiences!
Yes, this behaviour is known: when solar holds the leisure battery at or above the Orion’s float voltage (13.5 V), the Orion sees the output voltage as “battery full” and stays in float even while driving. Since you already have the D+ signal wired to the remote terminal, I’d disable engine shutdown detection — it only adds uncertainty with a smart alternator — and raise the re-bulk voltage offset to about 0.3 V so the Orion reliably re-enters bulk whenever the battery drops below roughly 13.2 V. The Orion XS would indeed improve things a bit (better adaptive charging logic and engine-on detection), but with the Tr Smart the D+ signal plus a larger re-bulk offset usually solves exactly this.
