Good morning everyone. This is going to be a longer post, as I would really like to understand why the Orion regulates things the way it does.
First of all, here is my hardware setup, after I spent quite some time trying to work out where to get the “real” D+ from. The problem with my vehicle is its smart alternator. It appears to deliver “wild” voltages at “its” D+ output, which the ORION could not do anything with. Neither via the high input (D+), nor through the automatic alternator detection based on the voltage present.
At some point I found a “conditioned” D+ on my Nordelectronica EBL, which allowed the ORION to be prompted to charge. But first, here is my hardwire setup.
Although I have installed a SmartShunt, the BMS of the SuperVolt Pro battery connected to the Cerbo via CanBus handles the charging control. Originally, a different battery was planned, but it was not available. So the SmartShunt is actually redundant now. It does not cause any problems, though.
I process all of this data in ioBroker, which has a dedicated adapter for Victron devices. It shines with more than 4,000 possible data points that can be described. I write a large proportion of these DPs` to InfluxDB, where they are then analysed with Grafana. So all of the following diagrams are based on these recorded data points.
Can you tell me whether the recordings look plausible, and whether the whole system would follow a different charging profile—one that is healthier for the LiFePO₄—if the SmartShunt were the “controlling variable” rather than the BMS of the SuperVolt battery? The SuperVolt BMS is somewhat of a “black box” when it comes to its control behaviour.
I could offer another dozen or so data points, but this should perhaps be enough to get started.
Here is now a whole load of trend diagrams. To make them easier to read, I split the combined trends into individual lines.
Many thanks for your support.
