I am experiencing repeated spontaneous reboots of an original Victron Venus GX running Venus OS v3.81 (Normal), kernel 6.12.90-venus-6.
The problem also occurred with v3.81 Large. To isolate the cause, I have:
Disabled Node-RED and switched from Large to Normal.
Removed the microSD card.
Disabled VRM’s reboot-on-no-contact setting.
Disabled three third-party background services: PackageManager, ShutdownMonitor, and ExtTransferSwitch.
Confirmed that all three services remained stopped following another spontaneous reboot.
Verified that substantial memory remained available immediately before recorded reboots.
The reboots continue under these conditions. On October 13, the device restarted at approximately 9:04 PM and 9:42 PM PDT, with additional restarts earlier that evening.
The kernel consistently produces the following warning approximately 37 seconds after startup:
WARNING: CPU: 0 PID: 1323 at
/drivers/tty/serial/8250/8250_omap.c:1030
omap_8250_rx_dma_flush+0xf4/0xfc
CPU: 0 PID: 1323 Comm: vedirect-dbus
6.12.90-venus-6 #1
from omap_8250_shutdown
from uart_port_shutdown
from uart_tty_port_shutdown
from tty_port_shutdown
from tty_port_close
The device also reports watchdog boot status 2. However, I have not established whether the UART warning or watchdog is responsible for the spontaneous reboots.
Could you advise:
Is this UART DMA warning a known issue in Venus OS v3.81 on the original Venus GX?
Is there any known relationship between this warning and unexpected watchdog resets?
Is there a recommended stable firmware version for this hardware, or a diagnostic procedure that could distinguish firmware instability from a hardware or power-supply fault?
I can provide the complete kernel trace and timestamped diagnostic logs showing system uptime, CPU load, and available memory immediately before and after the restarts.
Thank you for your assistance.
