Yes, use the new S2 nodered module (resource node)and send the ombc control signal to the relay (using a suitable function or node to convert the payload to the right format).
I do this currently with a virtual switch but it could be any switching device or relay.
There are examples included with the S2 resource node for guidance. This is a screenshot of mine showing the interactions, functions are pretty much just checking for bad data and converting the source into a payload the target node expects.
In my case I am using a Tuya device for data and the target of a virtual switch.
The resource node needs to be sent the device power and and a state acknowledgement when it requests and on/off - though you can skip this and enable a default, automatic ack in the resource node control itself.
You have to see, how that goes. Depending on the load size and available solar it will for sure start at one point, but internal maths won’t really work out, as OL currently only supports ACLoads, as the underlying S2 Standard only supports that by now.
(Our CR to add a Commodity DC is already submitted )
