Opkg update failing
Just tried to run opkg update on a CerboGX running version v3.60~26 and I’m getting a succession of errors like this:
Downloading https://updates.victronenergy.com/feeds/venus/release/packages/scarthgap/all/Packages.gz.
 * opkg_download_backend: Failed to download https://updates.victronenergy.com/feeds/venus/release/packages/scarthgap/all/Packages.gz, wget returned 8.
This was working fine a few weeks ago.
Checking Index of /feeds/venus/release/packages it looks like scarthgap no longer exists and the packages are now under dunfell
Should I be using the dunfell release instead?
How do I get opkg to use the dunfell release?
Cheers,
Andrew
Given that scarthgap is 5.0 release Yocto (which I assume is used as part of the Venus Open Embedded OS) and dunfell is release 3.1 I assume I need to use scarthgap and not dunfell?
Victron is working on it, give it a try in a few days.
Hello sir, do you mind to look into this post? You gave some valuable inputs previously. Thank you!
it is still not working, what is wrong?
Same here. I’m trying to install ntp but am unable to.
