Opendtu-issue
I guess i have the same problem here, yesterdays update to v3.71, made my battery stuck at 84% with low voltage. Can’t charge nor discharge anymore. Reboot to v3.70 does not help. No USB Stick, NodeRed running. Need to get the battery running again, please.
most of the times these are modified systems. Did you modify it?
just using GitHub - henne49/dbus-opendtu: Integrate opendtu and ahoy into Victron Energies Venus OS as a pv inverter · GitHub and GitHub - funkmaster86/dbus-shelly-pro-3em-smartmeter · GitHub should no effect the battery ?! an worked till yesterday.
That really has nothing to do with this issue, moved.
Maybe i found something: my battery has a can bus connection, using 9600 baud. checking Settings→Connectivity→VE.Can port→CAN-bus profile is set to CAN-bus BMS LV (500kbit/s), is this right?
Here the solution: Nothing to do with the firmware, nothing to do with the baud….after over 2 years the screws on the Lynx Distributor have come loose :face_with_bags_under_eyes:
