I need to install shutters on the connection points of the Type 2 socket, or switch to a Type 2S socket.
As I understand it, French standard NF C 15-100-7-722 requires this to improve safety.
Is it possible to replace the EVCS’s Type 2 socket with a Type 2S socket? If not, are there any shutters that can be added to a Type 2 socket? Or, as a last resort, how can I secure the cable to the charging station?
Regards,
To date, there is no shutter that can be fitted to Type 2 sockets.
We have some plugs under test, but nothing conclusive so far.
This is a uniquely French issue.
One solution that complies with the standard is to use a charging cable rather than a socket outlet. The plug can be mechanically locked in the socket outlet to prevent its use; this is provided for by an M6 screw.
This is what many manufacturers do to address the issue (Fronius and SolarEdge, for example), but even so, things are a little unclear for some EV charging installers.
The shutter requirement stems from NF C 15-100 for socket outlets, and from NF C 61-314 for extension leads and power strips. However, charging sockets are covered by NF EN 62196, which does not require a shutter, for the simple reason that without a connection to the communication cable, there is no voltage on the power contacts.
The next Victron charging station with a display will have a fixed cable to address this issue.
Thank you for your reply. I’m trying to locate this M6 screw, which allows the plug to be mechanically locked into the socket to prevent it from being used. Could you tell me how to proceed or offer any guidance? I couldn’t find anything in the manual, and given the illuminated strip around the charging point, I’m wondering how to access it. Another question: do I need a specific charging cable that can be secured with this M6 screw, or is it a standard cable that needs to be drilled at a specific point so the screw can hold it?
Thanks
You need to open the terminal and access the base; the opening is on the upper part of the base.
Thanks very much, got it. Indeed, you need to dismantle the charging post, then remove the two Torx screws holding a small rectangular cover on top. Remove this cover to access a hole where you can fit an M6 screw up to 20 mm long to secure a Type 2 cable, which will therefore be pierced by the M6 screw.
Normally, it won’t need to be drilled; Type 2 plugs already have a notch for the locking mechanism, and this hole lines up with it!
