So, folks,
first of all, many thanks for all the helpful comments. I’ve learnt quite a lot again.
The situation for me is simply that I started out with an SMA system in 2019. If I had known then what I know today, I would probably have built everything around Victron from the outset. But there you go — hindsight is always 20/20.
The existing technology can’t really be operated off-grid. If I want to switch to Victron, I should really do it consistently throughout. So I worked out what a complete conversion would cost.
Basement (main system)
New purchases:
- 3 × Victron MultiPlus-II 48/8000: approx. €3,300
- 2 × Victron SmartSolar MPPT RS 450/200: approx. €3,000
- would replace the SMA STP 8000 and STP 9000
- Pylontech US5000, 24 kWh (5 modules): approx. €3,900
- the SBS 5.0 with BXD HVL 7.7 would be taken out of service
- DC busbars, fuses, cables, etc.: approx. €1,500
- Könner & Söhnen KS 8100E ATSR Silent diesel generator: approx. €1,500
- Generator cable set and AC connection to the Skylla and ATSR: approx. €300
- Victron Skylla-i 48/100 charger: approx. €1,100
- Socomec ATyS 4-pole 125 A mains changeover switch: approx. €650
Shed (approx. 50 m away)
New purchases:
- 2 × Victron SmartSolar MPPT 150/60 VE.Can: approx. €1,000
- would replace the SMA STP 5000
- additional Cerbo GX: approx. €350
Existing components from the garage:
- Victron MultiPlus-II 48/5000
- Felicity battery with 15 kWh
Total cost
Materials only, excluding labour and modifications:
approx. €16,600
If I work out the cost of modernising the system with current SMA technology instead, I end up even higher. I’m also not sure whether I really want the new SMA technology. These days, there’s a lot of relabelled Chinese hardware behind it, and some of the devices are heavily dependent on the cloud and the manufacturer. Would that really be a good thing in the event of a global conflict?
In the end, I would be investing around €16,600 so that the system would actually do little more in everyday use than it does today. I would have more storage, genuine off-grid capability and a considerably more robust backup-power concept. But the question is, of course, whether it’s worth that price to me at the moment.
That would be a little bit of prepperism.
If Putin’s henchmen were actually to enter a NATO country one day, I’d probably think about it differently. Hopefully there would still be time to place orders and carry out the conversion. For the much more likely scenarios — a power cut lasting several hours or a couple of days as a result of grid faults or sabotage (eco-terrorists or expendable agents) — a much simpler approach seems more sensible to me.
That’s why I’d like to return to my original plan for the time being.
In an emergency, I don’t need to supply the whole house. Essentially, the groundwater pump and the heating system are all I need.
I’ve therefore decided to start by buying a manually started 6 kW inverter generator from Könner & Söhnen for around €700.
That would give me two options:
- Run the heat pump directly.
- Recharge the battery.
For charging the battery, I wouldn’t use the MultiPlus, but a separate 48 V charger. I’m quite interested in the server PSU approach. If anyone has practical experience with an Eltec Flatpack2, or knows of a neat, tried-and-tested solution, I’d be very interested to hear about it.
I could also envisage disconnecting six of the 18 PV modules on the garage roof from the SMA strings and putting them on a separate Victron MPPT 150/60. This would then operate on the same DC side as the MultiPlus, the Felicity battery and the charger.
That would give me a simple backup-power solution with a generator, battery charging and a small off-grid PV component for comparatively little money.
I’ll test whether the heat pump runs on the MP2 5000; I may need to limit it to 16 A or so, but that should be possible.
The system could then be expanded gradually: whenever an SMA device fails or needs to be replaced for some other reason, I would switch to Victron equipment.
We’ll see where the journey takes us.
