I got a problem with the installation of node-red modules. When I try to install a new module in node-red, it takes to long to install and after 2 minutes the connection with the VRM is lost, the cerbo is blocking and after 4-5 minutes the cerbo is rebooting. I update already all the software to the last version, without any success. I tried already to install node-red modules via the local way, so without VRM, this gives me the same problems.
2026-10-28T08:14:38.690Z [err] npm warn deprecated node-red-dashboard@3.6.6: No longer maintained - please look at alternatives such as @flowfuse/node-red-dashboard or node-red-contrib-uibuilder
That is expected as a “reinstall” option, this does not in itself remove any modifications, a full factory reset, as documented in the manual, is required for that.
For nodered issues on it’s own, just go to settings → integration and choose the reset option for nodered, this just completely resets nodered to a new installation. You can reconfigure from there.
When something gets corrupted, this is usually the only way to recover.
Confirm the watchdog event from the log I mentioned, you can also chart the dbus roundtrip time advanced widget, this will show if CPU is an issue.
Crashes usually are either a cpu overload, or when installing, the compiler exhausts memory. Both will trigger the watchdog and the reason will be in messages.
root@nanopi:~# grep -i “watchdog” /var/log/messages.0
Oct 28 08:16:20 nanopi daemon.err watchdog[420]: loadavg 13 11 5 is higher than the given threshold 0 10 6!
Oct 28 08:16:24 nanopi daemon.err watchdog[420]: repair binary /usr/sbin/store_watchdog_error.sh returned 253 = ‘load average too high’
Oct 28 08:16:24 nanopi daemon.alert watchdog[420]: shutting down the system because of error 253 = ‘load average too high’
Oct 28 08:16:24 nanopi daemon.err watchdog[3198]: /usr/sbin/sendmail does not exist or is not executable (errno = 2)
Oct 28 08:18:37 nanopi kern.info kernel: [ 0.108755] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=1)
Oct 28 08:18:37 nanopi kern.info kernel: [ 1.112267] watchdog: watchdog0 running and kernel based pre-userspace handler disabled
Oct 28 08:51:09 nanopi daemon.err watchdog[420]: loadavg 18 11 5 is higher than the given threshold 0 10 6!
Oct 28 08:51:29 nanopi daemon.err watchdog[420]: repair binary /usr/sbin/store_watchdog_error.sh returned 253 = ‘load average too high’
Oct 28 08:51:29 nanopi daemon.alert watchdog[420]: shutting down the system because of error 253 = ‘load average too high’
Oct 28 08:51:29 nanopi daemon.err watchdog[7673]: /usr/sbin/sendmail does not exist or is not executable (errno = 2)
Oct 28 08:53:42 nanopi kern.info kernel: [ 0.109001] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=1)
Oct 28 08:53:42 nanopi kern.info kernel: [ 1.111328] watchdog: watchdog0 running and kernel based pre-userspace handler disabled
Your GX is overloaded. Time to upgrade to an external Cerbo mk3. Alternatively reflash it as factory default, then slowly add customisations, improving efficiency (reduce polling/updating, check versions are all current for drivers/mods etc) as you go.
Use top to identify what is creating a lot of overhead.
You can disable UI animations on the GX display settings as well to lower overhead.
What is your dbus roundtrip time chart showing?
I would suggest you raise the watchdog threshold for cpu, it does seem that the standard large image seems to be a bit much, albeit temporarily, for the internal GX.
