But cannot get a response when subscribing or publishing. I have managed to get it to function locally via Node-Red’s MQTT in node but not externally on MQTT Explorer.
No luck with it working when the VRM session is open (I assume you mean remote console, no issues with).
I am publishing: R//keepalive and subscribed to the topic: N//# for any data to be received.
I managed to get this to work via Node-Red and will try an test locally (LAN) on a test Venus GX if I get the time. I will keep you posted about this.
I have just confirmed it is working via LAN, this doesn’t take into account keepalive but this shouldn’t affect it if the new UI is open.
Therefore the issue must come from the VRM broker. Is it an account permissions issue? I did see somewhere that they had to whitelist accounts or is this incorrect?
