I have recently installed the following:
3 x Multiplus 2 6k5
Connected in a 3 phase setup and also used a Cerbo GX as the controller.
And a 16Kwh battery with JKBMS
I was now planning to actually start using the system and purchased a MK3-USB-C interface in order to communicate with the multi plusses.
The bus connection is done as shown in the manual, L1 => L2 => L3 and normally then the cerbo, however i disconnect the cerbo and connect that UTP to the MK3-USB-C.
first of all i started with VE Flash in order to update the firmware however, while the system is able to auto detect the comport it subsequently doesn’t want to connect to the multiplus.
After nearly pulling my hair out i gave up on that and just wanted to configure, however VE configure is also not working. It detects the target but whilst loading its capabilities it shows a communication error.
please i hope someone is able to help me
