I have a number of flows set up in NodeRed. They work well, and so does the dashboard. But after some time (I don’t know how long) of inactivity on the dashboard or in NodeRed, neither of them works any more, until I first switch NodeRed off in the console, wait a few minutes, and then switch it back on.
I’d like to be able to access my dashboard at all times, especially as I’ve now added a switch to it to control whether or not my EV can charge from my battery pack.
VRM. But if it’s possible to access it locally (I haven’t looked into it), that would be nice.
And, by the way, it takes an “eternity” after a restart before everything is up and running again.
(Welcome by the way!)
VRM has a timeout so I suspect this is normal.
On your lan use https://venus.local:1881 to access nodered. Or just venus.local for the remote console.
The dashboard url is accessible from the nodered view menu and varies depending on which version you are using.
I stopped Node-RED about 20 minutes ago and started it again after waiting for about 5 minutes. And it’s still not available (via https://venus.local:1881- Normally NodeRed can be found on this location. It either is starting and will show after a refresh (…)
Which GX do you have and what version of venus is it running? You can do a nodered reset via the remote console integrations menu which will do a clean reinstall.
I have a CerboGX with firmware 3.75. If I perform a factory reset, I’ll definitely lose my flows, right? So first get everything up and running, then export, and only then reset. Right?
Correct. You can try manually start it in safe mode.
Are you using any customisations like guimods or setup helper?
When something breaks nodered it can be quite unforgiving to fix.
Ah, a restart in safe mode works well. I’ve made an export and will then do a factory reset. Oh, and I probably don’t use anything you’ve mentioned. Just some counters and graphs. Plus a switch to choose between “all loads” and “critical loads”, along with a slider for the power used to charge the EV.
