I have set up a control system flow for monitoring RV electrical and plumbing system temperatures. The system triggers the appropriate fan to vent the compartment if it passes a certain threshold. With the recent Venus v3.80 update and the introduction of Show in UI, has anyone found a way to toggle the UI visibility of a virtual switch based on the output state of another switch?
Example: One virtual switch to turn on/off the system. When virtual switch 1 is ON, virtual switch 2 is visible in the UI. When virtual switch 1 is OFF, virtual switch 2 is invisible in the UI.
I am trying to toggle the visibility of two temperature switches based on the main ON/OFF switch state.
