# Node Red on 3.60 Fresh Install Invalid Property (Service,Path) Errors
**URL:** <https://community.victronenergy.com/t/node-red-on-3-60-fresh-install-invalid-property-service-path-errors/37286>\
**Category:** Node-RED\
**Tags:** node-red, diy, not-listed\
**Created:** [26 June 2025 02:10 UTC](https://community.victronenergy.com/t/node-red-on-3-60-fresh-install-invalid-property-service-path-errors/37286 "2025-06-26T02:10:55Z")\
**Posts on this page:** 1\
**Showing post:** 5
<div class="post-metadata">
**Author:** ![kristufer](https://avatars.discourse-cdn.com/v4/letter/k/e5b9ba/32.png) [@kristufer](https://community.victronenergy.com/u/kristufer)\
**Post date:** [26 June 2025 16:18 UTC](https://community.victronenergy.com/t/node-red-on-3-60-fresh-install-invalid-property-service-path-errors/37286/5 "2025-06-26T16:18:05Z")
</div>
I may have found the solution. For me the following link solved my issue.
> [@Unable to access the service endpoint:/victron/services/input-vebus](https://community.victronenergy.com/t/unable-to-access-the-service-endpoint-victron-services-input-vebus/35558/8):
> First just pull in the Victron node on to the canvas and click “Deploy” This will give you a warning, but click “Confirm deploy”. Then, double click the Victron Node and you will get the dropdown for the services. After that, click deploy again and the nodes will work (you will only need to do this once).
_[View the full topic](https://community.victronenergy.com/t/node-red-on-3-60-fresh-install-invalid-property-service-path-errors/37286)._
