On your lan, yes.
Vrm is for remote access.
For me: what comes with OS-Large, plus:
- @mschaeffler/node-red-format
- node-red-contrib-average
- node-red-contrib-buffer-parser
- node-red-contrib-os
- node-red-contrib-ui-led
But there were no new Nodes installed since 3.6x.
And Iām accessing it direct, locally in LAN.
It does NOT happen when I deploy changed Nodes or Flows. Just when I do a full deploy.
But itās a minor thing anyway, at least for me. I just noted it.
Hi Nick. Yes. I installed nodes for Suncron and Shelly and have removed all non-victron now. Does not make a difference.
So safe mode all good. All tabs/flows disabled and NodeRed back to enabled also all good. But as soon as I enable the first tab it crashes again. Please note that my first tab is basically just a bunch read nodes to set global variables for use on other (still disabled) tabs. I have the dashboard installed but I donāt use it.
In short: have not been able to come up with anything useful ![]()
Indeed. This is caused by a bug that got introduced via node-red-contrib-victron-1.7.7 (in 3.80~10). Iāve just put 1.7.8 on the list for the next beta that fixes the āTypeError: Cannot read properties of null (reading ātoStringā)ā bug.
As far as I could determine only systems that have flows that carry a node that reads from the com.victronenergy.settings service where affected.
Disabled all nodes that read from the ā¦settings service and enabled everything else. It no longer crashes. Will wait for the next beta and confirm.
It is now available in 3.80~14.
Iām back in business!
8 posts were split to a new topic: Nodered nodes appear in grey colour not blue or orange
