No grid tie - Wind Turbine only
I’ve set up my system which is an ISTA Breeze i2000 wind turbine with two battery packs from Yixiang one is a 15Kwh pack and the second is a 32Kwh one. Both are user assembled and run on JK BMS’. The master BMS is connected to my Cerbo GX MK2. I’d like to set the Dashboard up to be offgrid. It will never be grid tied. Is there a way to change the dashboard to reflect this?
Just make sure the “ac in” is named as a generator - even if one is not connected.
Cheers Mike. For my understanding is there a reason for this? I take it to leave it on Automatic as well?
?? Leave what on “Automatic”?
Apologies. The system name. Automatic, Hub - 1 to 4 and ESS. As I’m not grid tied ESS is not the correct option and Hub - 1 to 4 is legacy systems.
You mean under “Settings” “System Setup”? At the bottom theres the option to set a custom name, which then gives you a field to type in. So you can name it whatever you want. But im actually not sure where this name is used
This name is only externally used by VRM.
@devan6969 : The name can be left as automatic, or change it to a custom name of your choice.
ESS is not needed or appropriate for this type of system.
