Hi, Complete newbie here. Would anyone be able to sanity check my wiring diagram please? I have a dual battery setup at the front of car with starter, Aux, Solar, MPPT and DC to DC. Some USB ports and camp lighting at front. Then cabling to back to Fridge and more USB ports. I think I’m missing a ground after smartshunt but not sure where to place. Thankyou link below:
No, don’t wire the starting battery to the shunt. This may work but that’s not what the the Orion manual states. If the starting and Aux battery don’t share a reliable ground with the Orion it may not function correctly.
You do have your grounding wrong for the DC-DC charger though. What Orion are you planning on using? Here is a wiring diagram from the Orion XS manual. This would apply to either the XS 50, 70 or a non isolated Orion(single ground terminal). If you ran your ground from the DC-DC to chassis ground instead of the negative bus bar you should be correct. Everything else, as far as the wiring connections go appears to be acceptable.
@TherealKT there is no shunt in this wiring diagram either.
If there is a shunt in the system, I recommend not using the chassis for the negative connection, but running a physical cable from the starter battery to the house battery. Since you also want to register the alternator charging current in the shunt, that cable must be connected to the correct terminal (to system minus).
The negative connection from the XS also goes on that side of the shunt.
Note: if you have a smart alternator, the negative cable at the starter battery must not be connected directly to the battery’s negative terminal, but to the starter battery’s shunt.
@VictRon54 Yes I think you are right. Sorry I failed to mention earlier (quite possibly because I don’t know what I’m doing) that I am combining two elements that confuse existing Victron diagrams.
I’m using a Victron IP 65 Smart Shunt monitoring mainly the House battery however I do have the option of monitoring my starter battery voltage via the Smart Shunt AUX cable which I’d like to do. In the Victron SmartShunt diagram below the Starter negative is connected to the Smart Shunt.
Is it saying the DC ground and starter/aux negs need to share the same ground? Because I am using the SmartShunt in the 3.5.1 diagram how should I wire in the DC to DC Ground?
To install the shunt in the XS wiring diagram, proceed as follows.
Disconnect the negative cable at the right-hand battery (auxiliary battery).
Place the shunt between them. There should only be one cable between the shunt battery minus and the battery.
Connect the cable from the starter battery to the shunt (load minus).
Unfortunately, Victron uses different names for the connection points on almost every shunt.
Connect the red cable to the positive terminal of the auxiliary battery.
To measure the starter battery voltage, connect the grey cable to the positive terminal of the starter battery.
Connect the XS negative terminal to the load minus on the shunt as well. It’s best to use a busbar, because there will probably be more negative cables connected at that point.
