I have 3 NPFC LiFePO4 Narada batteries in 48V DC and I consult how I can connect your internal BMS that works with protocol 485 to the CAN BMS protocol of the Cerbo GX or a Color Control GX de Victron. Maybe there is a converter. I thank you in advance for your comments
Can and RS 485 are two different protocols. You would need to write a driver and add something to the GX for it as far as I am aware.
There are a few posts for the modification for other batteries.
The most known one is this one
But if you search the forums or git hub (example) there will be others.
Excellent. With this information you open the information to another very interesting dimension. I will begin to study the alternatives that this path of knowledge offers me. Thank you very much for replying.
