Shunt wired up wrong with the MPPT negative is connected direct to the battery rather than the load side of the shunt and is bypassing the shunt and not being measured. The DC loads tile is a calc so if the shunt is not measuring solar then the DC loads is also wrong. See links below.
Related topics
| Topic | Replies | Views | Activity | |
| Shunt / battery monitor not reading the correct SOC/ Amps, missing solar, decreasing daily or other misreading problems | 2 | 3736 | June 5, 2025 | |
| DC Load match PV output | 4 | 72 | December 31, 2025 | |
| Orion XS - wrong data?!?! | 1 | 123 | May 6, 2025 | |
| Strange reading in DC current and charge current | 1 | 72 | October 22, 2025 | |
| Noob! Smart Shunt Set up on Sailboat - Incorrect SOC Showing | 7 | 173 | June 5, 2025 |
