My settings for 52 volt lifepo4 battery 16S with jkbms and multiplus 2 with DESS
Just for anyone searching for the settings for Ve Configure with a Lifepo4 Battery (16S) of 52 volt here are the VE.Configure Settings which work fine and I think (together with AI) these are the most optimal I think.
TAB: General
State of charge when Bulk finished 99.0 %
Battery capacity 314 Ah
Charge efficiency 0.95
TAB: Inverter
PowerAssist unchecked
Inverter output voltage 230 V
Inverter DC shut-down voltage 46.40 V
Inverter DC restart voltage 48.00 V
Low DC alarm level 47.60 V
Do not restart after short-circuit (VDE 2510-2 safety) unchecked
enable AES unchecked
TAB: Charger
Enable charger checked
Weak AC input unchecked
Stop after excessive bulk unchecked
Lithium batteries checked
Disable VSense (for diagnostic purposes) unchecked
Configured for VE.Bus BMS unchecked
Charge curve Fixed
Absorption voltage 55.20 V
Float voltage 54.40 V
Charge current 70 A
Repeated absorption time 1.00 Hr
Repeated absorption interval 14.00 Days
Absorption time 1 Hr
TAB: Virtual switch
TAB: Usage
Virtual switch usage Do not use VS
TAB: Assistants
TAB: Assistant Configuration
ESS (Energy Storage System) (size:1815)
*) System uses LiFePo4 with other type BMS
(This can be either a BMS connected via CAN bus (e.g. a Lynx Smart BMS) or a
BMS system in which the batteries are protected from high/low cell voltages by
external equipment.)
*) The battery capacity of the system is 314 Ah.
*) Sustain voltage 50.00 V.
*) Cut off voltage for a discharge current of:
0.005 C= 48.00 V
0.25 C= 47.20 V
0.7 C= 46.40 V
2 C= 46.40 V
*) Inverting is allowed again when voltage rises 1.20 V above cut-off(0).
*) Relevant VEConfigure settings:
- Battery capacity 314 Ah.
- PowerAssist unchecked
- Lithium batteries checked
- Dynamic current limiter unchecked
- Storage mode unchecked
Total size of all assistants including the required
(hidden) system assistants is: 1888
TAB: Advanced
limit internal charger to prioritize other energy sources unchecked
I also found this manual for Dyness batteries which is pretty conservative imo, but needed to guarantee vendor warranty: https://communityarchive.victronenergy.com/storage/attachments/dyness-battery-and-victron-inverter-setup-manual-2.pdf
Does this also work with 2 or 3 JK BMS units?
I think it works for most lifepo4 16s batteries.
It’s more based on the characteristics of the cells than the bms itself.
Those settings are for veconfigure, the jkbms itself has different settings which I can post if you need them.
