My NZ power station
Victron Solar & Battery System – Summary
Inverter / Charger
  • 1 × Victron MultiPlus-II 48/8000/110-100
  • 8 kVA nominal inverter capacity.
  • Approximately 6.4 kW continuous usable AC output.
  • Operating with Victron ESS (Energy Storage System) and Dynamic ESS / Trade mode.
Solar PV System
  • Approximately 15.5 kWp total solar capacity.
  • Includes 21 additional solar panels installed as an expansion.
  • Solar generation feeds the battery storage and supplies the property, with surplus exported to the grid.
Battery Storage
  • 4 × Freedom Won LiTE2 Home 10/8 lithium batteries.
  • Nominal voltage: 52 V per battery.
  • Approximately 10 kWh capacity per battery.
  • Total nominal battery storage: approximately 40 kWh.
Solar Charge Controllers
  • 3 × Victron SmartSolar MPPT 250/70.
  • 1 × Victron SmartSolar MPPT RS 450/100.
DC Distribution
- Victron Lynx Power In / 1000A DC distribution system.
Looking good! How do you find the production of the flat array versus the tilted during your shortest days? I guess it doesnt really matter if you can use your grid feed in credits, good for overcast ime.
As you’d expect, the tilted panels produce more in winter with the sun lower on the horizon, but in the summer the sun is almost directly overhead, nullifying any advantage. I bought the panels for the container cheap, so it was kind of an afterthought, not really planned. The shade from the panels dropped the temperature inside the container by about 8-10C, so that is an incredible bonus and almost worth the cost of putting them up there just for that reason.
