My system is Victron Multiplus compact charger/inverter 12/2000 80 installed 2018
There is no Bluetooth on this unit. Its has been working for 8 years no dip switchs have been changed
Its dead and wont switch on, the remote-control panel is also dead. I have confirmed both mains 230volts and 12volt are present.
I’ve checked 12volt past the internal fuse and its ok to that point.
I have tried turning it off 4 seconds then on again but it still dead.
I did disconnect the mains yesterday with the aircon running could this have caused this?
Description of failure: unit wont switch on, I tried resetting power off 4 seconds power on, when toggling the main switch led lights flicker for a second then go out, the remote controller seems dead
I carried out the following steps to reset and test the unit:
- Removed all solar power input.
- Removed the positive 12‑volt feed from the battery.
- Confirmed there was 0 volts across the 12‑volt input terminals, then removed both the negative and positive wires.
- The 240‑volt input and output wires had already been removed. These were temporarily connected together to provide mains power to the motorhome
- Unplugged the data cable.
- Waited 2 minutes.
After this:
- Reattached the 12‑volt feed and reconnected it to the battery. Voltage measured 13.9 volts across the negative and positive terminals.
- Toggled the switch next to the LED, but the unit did not start. No LEDs illuminated at all.
- Reconnected the data cable and tested again. This made no difference.
Fault Summary: The unit does not power up and shows no LED activity despite a confirmed 13.9‑volt supply and a full reset procedure.
My Desired solution: is an out of warranty repair possible
