I wanted to try what would change when I disable the UPS function on my MultiRS with the consumption when idle.
I have got a MultiRS 3Phase installation.
Software 1.31 latest multiRS version.
Where do I found this function, I don’t see it in the Victron Connect application, it is not there under Grid…
but it was seen in pictures from the multiRS in this list.
A image from the printed manual page 30, you can’t switch off the ups function by this switch…normal RS6000 operation is already UPS mode.
I can’t find the switch either, it must been removed by an update..
It is editable depending on the grid code used.
I use the Europe Grid code.
Is this why I don’t see the UPS function?
If so, why is this that you can or cannot disable the UPS function depending on the grid code you use.
If you don’t want this?
George
Because the regulatory offices set the requirements for connecting to their grid services.
Their rules.
Okay thank you, didn’t know that
