# Multiplus won't turn on
**URL:** <https://community.victronenergy.com/t/multiplus-wont-turn-on/5215>\
**Category:** DIY\
**Tags:** mppt\_controllers, beginner, marine, victronconnect, multiplus\
**Created:** [26 September 2024 10:04 UTC](https://community.victronenergy.com/t/multiplus-wont-turn-on/5215 "2024-09-26T10:04:09Z")\
**Posts on this page:** 1\
**Showing post:** 2
<div class="post-metadata">
**Author:** ![guystewart](https://dub1.discourse-cdn.com/victron/user_avatar/community.victronenergy.com/guystewart/32/1_2.png) [@guystewart](https://community.victronenergy.com/u/guystewart)\
**Post date:** [26 September 2024 11:27 UTC](https://community.victronenergy.com/t/multiplus-wont-turn-on/5215/2 "2024-09-26T11:27:11Z")
</div>
Hi @GavDog,
Here is a step by step procedure that is used to isolate a potential fault and see if it is a warranty situation.
[https://www.victronenergy.com/media/pg/Pre-RMA\_Bench\_Test\_Instructions/en/pre-rma-test-form---inverter.html](https://www.victronenergy.com/media/pg/Pre-RMA_Bench_Test_Instructions/en/pre-rma-test-form---inverter.html)
It’s mainly focused on isolating the Multi and connecting it to a known good DC power supply, but give it a read and then a run through if you can. It might help narrow down the cause.
_[View the full topic](https://community.victronenergy.com/t/multiplus-wont-turn-on/5215)._
