Multiplus with external switch keeps rebooting and doesn't respond to the switch
I installed a Multiplus 12 | 800 | 35 which worked just find the past weeks. Now I added an external relay to remote switch it off when the engine of my car is turned on. I connected the relay to the remote terminal using the + and the ON to be connected when the engine is off. When turning the engine on the relay opens and the ON and + get disconnected.
I changed DS-1 to ON and did the DS-6 OFF-ON-OFF cycling.
With this configuration the Multiplus keeps turning on and off every 30 ~ 40 seconds and doesn’t respond to the relay being opened. So it stays on when the relay is open and the connection between + and ON is broken.
What am I doing wrong and how to fix this?
Thanks for your help.
