Dear all,
I have done an Energy Managment System using Node-Red, this system in order to optimize the amount of energy going in the battery is changing the DVCC charge current limit using an ESS output node, the rate of update of the DVCC charge current limit is every two minutes. The question is considering this rate of update there is an issue regarding the memory wearing of the Multiplus using the ESS node to control the current?
Many thanks for your help
Fabio
