Multiplus II GX and ABB Terra AC
Is it possible to link the ABB terra ac ev charger to the gx ? If not, as I’m running home assistant and mqtt having the gx connected, is it in some way possible to tell the system the power the charger is using ? I’m making use of ESS and will try Dynamic ESS so I want to avoid to override settings as it may interfere. I’m using a Victron Energy VM-3P75CT meter in my setup.
