Multiplus-II GX / AC current sensor / AUX input wrong way around in documentation
I happened to notice that the online documentation for the Multiplus-II shows the AUX 1 & 2 inputs in an ambiguous order. (I didn’t check my paper copy.)
In the Connection Overview in the appendix, the image shows the ports in order:
K1
Ext GND Relay
AUX 2
AUX 1
T-Sense
V-Sense
The table (just below the diagram) lists them as:
  1. Auxiliary power supply 12 V 100 mA
  2. Programmable open collector ooutput (K1) 70V 100mA
  3. External ground relay +
  4. External ground relay –
  5. Analog/digital (AUX) input 1 +
  6. Analog/digital (AUX) input 1 –
  7. Analog/digital (AUX) input 2 +
  8. Analog/digital (AUX) input 2 –
  9. Temperature sense +
    10 .Temperature sense –
  10. Battery voltage sense +
  11. Battery voltage sense -
I had configured and wired up according to the table, expecting to be using AUX 2, and the sensor showed my AC-coupled PV input reading maximum (~2.5kW) regardless of solar input. That in itself is quite an interesting and unexpected open-circuit behaviour.
Moving the wires to the next position along predictably fixed things.
Just thought I’d share the inconsistency in case it trips anyone else up.
What is printed next to the connections at the device?
I always use that as reference.
Yep. Absolutely.
I actually could not easily see, as the device is quite close to the floor. I guess I could have taken a snap on the phone.
