Multiplus ii and Pylontech system using the grid as well as solar excess to charge batteries
Parallel can add variables.
Setpoint issues can happen if the units aren’t properly matched - age differences etc.
The newest should be master.
If you use a clamp meter you can measure individual inverters to see which one is causing the issue or if there are imbalances.
I put a flow in the nodered category that allows this to be done via a dashboard:
