# Multiplus II 5000va Grid Export , AC Coupled Inverter , ESS VenusOS AC2 not working
**URL:** <https://community.victronenergy.com/t/multiplus-ii-5000va-grid-export-ac-coupled-inverter-ess-venusos-ac2-not-working/36111>\
**Category:** DIY\
**Tags:** pv\_inverter, parallel, victron\_community, multiplus-ii, ess, diy\
**Created:** [17 June 2025 05:11 UTC](https://community.victronenergy.com/t/multiplus-ii-5000va-grid-export-ac-coupled-inverter-ess-venusos-ac2-not-working/36111 "2025-06-17T05:11:24Z")\
**Posts on this page:** 1\
**Showing post:** 2
<div class="post-metadata">
**Author:** ![DuivertNL](https://dub1.discourse-cdn.com/victron/user_avatar/community.victronenergy.com/duivertnl/32/279_2.png) [@DuivertNL](https://community.victronenergy.com/u/DuivertNL)\
**Post date:** [17 June 2025 05:18 UTC](https://community.victronenergy.com/t/multiplus-ii-5000va-grid-export-ac-coupled-inverter-ess-venusos-ac2-not-working/36111/2 "2025-06-17T05:18:32Z")
</div>
Hi could this be the problem:
> [@Inverter Clicking every 4 minutes, output drops briefly, then rapid relay clicks](https://community.victronenergy.com/t/inverter-clicking-every-4-minutes-output-drops-briefly-then-rapid-relay-clicks/35858):
> Hi everyone, I’ve just received a new Multiplus 2-GX and have encountered an issue during testing. I connected a battery, applied 240Vac to the input, and connected a 30W light to the output. The inverter powers the light initially, but approximately every 4 minutes, it makes a clicking sound, the light blinks briefly, and then a series of 3–4 rapid clicks follow. This same behaviour happens even with no load connected to the output. Has anyone experienced something similar or have any idea …
_[View the full topic](https://community.victronenergy.com/t/multiplus-ii-5000va-grid-export-ac-coupled-inverter-ess-venusos-ac2-not-working/36111)._
