MultiPlus-II 48/6k5/100-50 (internal relay): Is EN 50549-1 sufficient or is Ziehl UFR1001E required?
Hi everyone,
I am planning a grid-connected residential installation in Croatia (HEP grid) using a single MultiPlus-II 48/6k5/100-50 operating in “Ignore AC” mode. The system is intended to be an emergency backup for critical loads during external black-out, but, at the same time, using PV panels and battery, as an energy saving solution (without ESS). The system should use the internal transfer relay of the MultiPlus-II (standard configuration).
I recently came across the Victron manual for the External Transfer Switch application, which mentions that for EN 50549-1 an external Ziehl UFR1001E relay is required. Could you please confirm that for a single MultiPlus-II installed in the standard way, using its internal transfer relay, the standard EN 50549-1 certificate is sufficient for the grid interface?
Thank you for your support!
