The TAB L5.1 battery has 16s LiFePo. Can another battery with 16s LiFePo and identical voltage settings be connected to the Lynx, or does it have to be the same battery?
Good evening,
Well, it’s never good to use “other” batteries then you already have, specially Lithium.
As, fore shure there are always little differences in between them, like another BMS for sure, or slightly different cells, etc.
Stick to the maker and type you have, but, yes some makers batteries are compatible, like pylontechs 2.5kw and 5kw can be used “mixed” among a few other brands.
Regards, Jeroen.
as long as the number of cells and their nominal voltages are the same, there’s no problem connecting all sorts of batteries in parallel.
However, that isn’t always possible with BMSs from different batteries. There’s a project called BSC that makes it possible to combine several different BMSs into one.
I’ve done this with three batteries using three Cerbos. Otherwise, I would have had to update the BMS firmware. This was the simplest solution for me without any additional hardware.
Cheers
Hello d_ferdi,
I prefer the idea of a new battery with its own Cerbo to the bsc project. The batteries would both be connected to one Lynx. The voltage settings would be the same, of course. Set the current limits for both to those of the weaker battery, so that the limits aren’t exceeded if one battery fails.
Are there any other important settings or things to bear in mind?
voltage limits are more important than current limits, because then it’s unlikely that the current limits will be exceeded. However, you do need to make sure the maximum possible discharge current can be supplied, otherwise the system may shut down!
I’ve collated the data from all the BMS units and send it to my central MQTT server. I haven’t had any problems with outages so far.
But there’s one other really important thing. If you’re using different battery types or batteries of different ages, their charge curves can shift, so the currents may not be distributed in proportion to their capacities. Instead, they could be split 9:1 or 1:9, or somewhere in between. Even if the batteries reach full charge at about the same time, there can still be significant differences in their SOC beforehand. The same applies when discharging!
You should definitely keep this in mind. For example, I use Pylontech and EVE batteries, and the difference is really extreme. But since each battery is large enough to handle or supply the total current, it’s absolutely no problem! No matter how the current is distributed, the current limit will never be reached!
Here are some data on that:
akku.zip (151.2 KB)
Cheers
