MultiPlus-II 12/3000 versus a GFCI socket
I have a MultiPlus-II 12/3000 installed in my motorhome.
The problem I’m having is this: when I plug my motorhome into a GFCI socket, the socket’s circuit breaker trips after a few seconds. However, if I plug my motorhome into a standard socket (without GFCI), everything works properly.
I have this problem at home and at every campsite that has this type of socket.
Has anyone else had this kind of problem, and how did you fix it?
Thanks in advance for your comments!
Best solution: Install an isolation transformer on the AC input to the motor home. This is a very common problem.
Check the leakage current of the various mains filters (measure the current at PE).
And check the N–PE insulation resistance at the mains inlet of your motorhome.
Please describe exactly how the MP is connected (according to the Victron wiring diagram or your own setup).
I have nothing good to add here, I ended up working around it. I had an extra 12v LFP converter that was sitting around and decided I would just use it to power the 12v bus and the MP2 inverter while it is in storage and do not connect the shore power. Obviously I cannot run ACs off that, but I have enough battery power to run 1 AC for several hours if I needed.
