A question for the experts: Is it possible to configure the Multiplus 24V 800VA to feed-in (feed energy back into the grid) without an additional GX device?
Exporting requires ESS, ESS needs a compatible system and a GX.
I know how to do this using ESS and GX; I am interested in the possibility of doing it without them.
There is no possibility, thats why I stated it as a requirement.
To expand a bit on this, the Multiplus is controlled over VE.Bus. VE.Bus is a proprietary system. To my knowledge theres no non-Victron solution to control a VE.Bus device. So you either need a true GX device or use an Mk3 VE.Bus to USB adapter connected to a RaspberryPi (or similar) running VenusOS (Also here im not aware of any non_VenusOS solution).
Just by terminology, as soon as you feed back to the grid, the system is an ESS, even it would be controlled by some non-Victron system.
Apart from that, the smaller MPs non-MP2s do not have double ACin relays internally, so in order to legally feed back to the grid, you would need to use an external anti-islanding relay. The Ziehl UFR1000 for example costs as much as an MP2 24/3000. Hardly worth it.
Only the MultiRS can do ESS without a GX, but those are 48V only.
If its just about feeding back, consider using a microinverter instead. Like a Hoymiles together with openDTU/ahoyDTU to control it.
I understand.
P.S. I started with a Multiplus 24/800 and 2x 24V 100Ah LiFePO4 batteries, and eventually switched to an MP2 and 2x Dyness B4850 batteries to power my home. The Multiplus 24/800 is currently set up for emergency backup, but it’s sitting idle and unused. I planned to turn it into a storage system—storing 5 kWh and later feeding that energy into the MP2 as needed. So, I’m looking for a way to feed that energy back into the MP2 without extra cost, and I had hoped I could do it via the AC-IN port, just like the “big brother” model does.
If it isn’t posible to do I will sell my old system and will buy additional B4850.
Why is that? There are situations where a lower-power inverter can come in handy.
Possibly portable too (disaster preparedness).
Currently, the Multiplus 24/800 is set up as an emergency backup power system, but it is simply sitting idle. I no longer use this unit to power the house, as I have a new one.
I had planned to convert it into an additional energy storage system (with a 5 kWh capacity)—charging the batteries at a lower tariff and using the stored energy during the day or in emergencies—but I lack the ability to feed this energy back into the grid, and the Multiplus 24/800’s power output is sufficient only for emergency backup of a limited set of loads. I am not entirely happy with this arrangement, as it effectively becomes a standalone system capable of charging but lacking the ability to fully discharge.
