MULTIPLUS 2 - PV AC OUT - MultiPlus/Inverters - Question: Battery full - Grid OFF - PV production?
If the solar inverter keeps shutting down, I would look to switch out that inverter as that voltage is withing the grids operating range so that should conform to that range as per the grid code for your country unless the solar inverter isn’t for your market?
The VTAC stopped. I’ll try another test at midday with a full battery, the grid switched off and a small amount of solar generation, and see how the AC voltage at the inverter terminals changes. But I think it cuts out slightly before 253 V (at 250 V).
I’ll make sure. What’s good about this aspect is that it cuts out before the frequency rises, so it will shut down before the SMA. Then, if the SMA really does continue producing with the battery full, it will shut down as well.
With my grid-coupling and possible islanding setup, the system is at least safe.
It restarts by itself correctly after 300 seconds.
Thanks for the feedback and thoughts in the previous messages.
Yeah so at least it’s cutting out , but should go to least 253v as that’s the normal operating ceiling height for your grid as during the day if your grid voltage rises the victrons will have to rise to push back if your exporting which would see production shutdown for that inverter at 250v.
But yes you need to make sure that this isn’t a 1 off and it repeats this consistently, if so at least from a safety aspect you won’t have to worry about the system going into island mode and cooking the batteries or forcing it’s BMS to shut the whole thing down :call_me_hand:t5:
