Multiplus 2 15000 external transferswitch von envitec
Hello, I’d like to set up a system with 3 x MP2 15000 units running firmware s.99 and an external transfer switch from Envitec. It has an ABB CM-UFD relay installed instead of the Ziehl relay. Is this configuration possible? Technically speaking, the ABB meets all the same requirements as the Ziehl relay. The only difference is that the Victron system’s pre-configuration would need to be entered manually, whereas the Ziehl has this onboard.
I’m well aware that I’ll also need a second ABB MCCB for this. I already have one.
I’d be grateful for a qualified answer.
Best regards
