Multiple "remote" temp sensors for Gx (over network)?
I’d like to be able to monitor a handful (say 5) temperatures outside of the direct bluetooth / wifi range of the CerboGX controlling my system. The Cerbo GX is located in an outbuilding some distance (50m) from the main properties network, and uses an IP over powerline Network expander to brance the main properites network out to that outbuilding (as a hardwired ethernet port, not wifi)
Are there any off the shelf solutions available from any compatable vendor that can sit on any part of the physical network and read temperature sensors natively? I’m happy to use node-red to build a custom solution, probably Ruuvi Bluetooth sensors with a remote network based local bluetooth adaptor, or a ethernet to RS485 bridge into some industrial automation serial temp sensor devices etc
What are my options here?
What kind of sensors do you need? I use Shelly devices for that. One sensor is DS18B20 connected to Shelly Plus Add-on which is then connected to Shelly smart switch (multiple models are compatible). You can have up to 5 DS sensors on that add-on.
The other sensor is Shelly BLU H&T which talks over Bluetooth to the same smart switch. But that Bluetooth sensor needs to be within the range of smart switch.
Communication is done through MQTT and Node-Red then creates virtual sensors in Gx.
