I’m in the process of building a setup with 3 Multi RS solar systems.
At first to convert PV to 230V but also to be prepared to add batteries in the future.
The MPPT input of the Multi RS will be coupled to 20 * 480Wp Aiko PV panels (7S+7S+6S)
Here originates my question. The Aiko 480Wp panels are capable of providing 13.92A
The Multi RS solar Maximum operational PV input current: 12 A per tracker
Question: what will the operation method of the Multi RS be when a current larger than 12A is provided?
And/or would it be an option/better suited to install 3 Multi RS 230V in combination with a separate MPPT device capable of handling 20*480Wp
The maximum power per panel (in full sun) will be limited to around 400W by the 12A current limit of the Multi RS Solar – this is a problem for many modern high-output panels.
If you want to avoid this you need to fit a separate MPPT controller with enough current capacity.
