# Multi RS Solar 48/6000 Maximum operational PV input current limit
**URL:** <https://community.victronenergy.com/t/multi-rs-solar-48-6000-maximum-operational-pv-input-current-limit/48392>\
**Category:** DIY\
**Tags:** multi\_rs, diy\
**Created:** [8 November 2025 15:42 UTC](https://community.victronenergy.com/t/multi-rs-solar-48-6000-maximum-operational-pv-input-current-limit/48392 "2025-11-08T15:42:46Z")\
**Posts on this page:** 1\
**Showing post:** 25
<div class="post-metadata">
**Author:** ![stok47](https://avatars.discourse-cdn.com/v4/letter/s/91b2a8/32.png) [@stok47](https://community.victronenergy.com/u/stok47)\
**Post date:** [14 November 2025 04:29 UTC](https://community.victronenergy.com/t/multi-rs-solar-48-6000-maximum-operational-pv-input-current-limit/48392/25 "2025-11-14T04:29:01Z")
</div>
Good day Philsc,
Im running version v1.25.
and I have the older model multi rs with one mppt tracker, come to think of it - thats probably the reason I am getting more amps per mppt. I remember when the dual tracker multi rs came out, the power was 3000W per tracker, and my single mppt is 4000w
found a old data sheet for the single tracker multi rs. 18Amp pv input limit, and indeed in the data sheet of the dual mppt it is 12 Amps I also see the short circuit current is 16A vs 30A
based on this (old) newfound information I would rather suggest you keep to Victrons specification for warranty purposes.
 ![image](https://europe1.discourse-cdn.com/victron/original/3X/0/6/06489c96e6a0fb277c342fa813ca6e96a1b39d55.png)
_[View the full topic](https://community.victronenergy.com/t/multi-rs-solar-48-6000-maximum-operational-pv-input-current-limit/48392)._
