Multi RS 48/6000/100 trackers imbalance
Hi
I have multi RS solar. 48/6000/100. This is the mark 2 version with dual MPPT’s. I have an issue when one tracker produces over 1000w approximately the other gets throttled back. The primary one will produce 2500w-3000w. The other tracker gets suppressed to 160w, maybe less.
Either tracker can dominate the other in this way. Only when the output drops to approximately 600w do they produce equally.
I have the latest firmware update.
It’s a newly installed system and has been like this from day one.
Essentially when one tracker goes up the other goes down.
Has anyone come across this before, I have read about cases but with no conclusion.
Are there settings that may have been overlooked. I suspect the issue is in the unit itself. It is NOT a supply or shading issue.
Out of curiosity are you feeding back?
Or is it just covering loads?
Is it really important that they ‘share?’
I have an east north so for mine it pretty much is never the same production wise
But can that energy go anywhere? The options are a battery or the grid, and they need to be able to handle it. That applies to the settings too.
I am just waiting for approval to feed back, should be through any day apparently. That is not the problem though.
When the battery( 3 x US5000 Pylontech) is 40-60% charged and I turn on a test load of 6000W + it draws it from the battery the second tracker does not ramp up, it stays at 13W.
The idea of this integrated system is that it runs 2 individual 3000w trackers. I have seen posts where people are producing that. At the moment I have a system that is equivalent to the mark 1 system producing 1 x 3000w. So I’m getting half what I paid for and expect.
The short answer to your question is yes it should be going to the battery or the demand.
A PV negative lead swapped from string A to B can also cause this symptom.
Are you absolutely sure that’s not the case?
Just clarify that for me please.
I have checked, checked and checked again, there is no reversal of positive and negative, DC in .
I will quadruple check there is no crossover from string 0 to string 1. ( I think that’s what you were referring to).
Both these trackers work, just not fully at the same time.
Yes, exactly. I once swapped the - connections of the strings and got the same behaviour. But to take measurements, you need to disconnect (unplug) the strings.
It’s also plausible that the system is throttling, but taking a few measurements is quick and easy to rule that out….
There is actually an error that appears when you do this.
If there is a crossover? Because I’m pretty sure I don’t have a crossover and there’s no error message.
Exactly. You would get a ground error.
:man_shrugging:t2: In my case, there was no error message. That was 3 years ago; it was an Rs450/200. One of the two strings was always working, while the other idled along at a few watts, alternating between the two. No error message.
And the colleague who connected it was absolutely certain he’d done everything right.
So we can rule out a crossover then.
Strangely after toggling off ‘has dc system’ in the system setup yesterday, today there was an improvement and the system seemed to work in a more balanced way…at first. Then 1 tracker maxed out while the other was throttled almost to zero again.
I still don’t get why when I turn on a heavy consumption load, like 6000 W, both and MPPT’s don’t step up to supply the load. One carried on and the other did nothing and most of it came out of the battery.
If crossover is ruled out, it could possibly be some kind of limit. Besides the grid feed-in, there’s also the maximum current at the grid.
