Is there a Multi Control available with a dial that can be fitted after setting current limit so the limit cannot be altered?
Related topics
| Topic | Replies | Views | Activity | |
| Shore current limit won't change | 16 | 306 | August 3, 2025 | |
| How can I set an upper Input current limit and then reduce it on the road? | 4 | 913 | January 24, 2025 | |
| 48v Multiplus-II input current limit from AC: arbitrary minimum threshold? | 2 | 916 | June 13, 2025 | |
| Multiplus II 3000 | 2 | 105 | August 6, 2025 | |
| Multiplus II Not Limiting Current Input | 2 | 388 | May 5, 2025 |
