Multi can’t tell difference between gen & bat?
Ok, so if my batteries are at 52v and I want to charge them on a cloudy day, I turn on my generator which is 4.5kw via the ATS/VRM.
My multi is a 48-3000-35-50, so can only accept an input amperage of 8, which equates to about 1500w max coming from my generator.
However, before I turn on the generator, I notice the battery voltage at 52v, the generator goes on, it pushes out 58v, the multi immediately goes in to absorption and reduces the load from the generator to 600w! And I’m just wanting to charge the batteries up as quick as possible.
Is there any way for the multi to distinguish the difference between the actual battery voltage (that needs charging) and the voltage coming in from the generator?
Many thank Ian
