Hi everyone,
I’m looking to expand the data shown on my Cerbo GX (GX Touch display) by injecting custom sensor data via MQTT. I have two specific use cases:
1. Diesel Fuel Level I have a fuel level sensor available via an external system, and I want to push this value to the Cerbo GX so it displays on the main tank overview screen (the one showing water/septic levels).
What is the correct MQTT topic structure to inject a fuel level so the Cerbo treats it as a “Tank” device?
Do I need to create a “Virtual” tank in the settings first, and if so, how do I link the MQTT input to that specific instance?
2. Fridge Temperature I have the ability to read my fridge temperature via a sensor and publish it to MQTT.
Is MQTT the recommended way to get this temperature visible on the Cerbo GX display?
If so, which MQTT topic structure should I use to ensure it appears as a temperature sensor in the UI?
Any guidance or documentation references on the required JSON payloads and topics would be highly appreciated.
Thanks for your help!
