I’d like to connect 10 DMEG 470WP DM470G12RT-G48HBW solar panels to a 450 charge controller, but somehow it doesn’t show up anymore, or I’m doing something wrong.
Instead, it keeps showing Inverter RS 48/6000 230V Smart Solar?
But really, I only want to use the thing to charge the battery, in case of a zombie attack and all that… I don’t need the 230-volt part at all… the battery is 48 volts.
I can manage as it is, but does anyone know whether the MPPTs have been discontinued or anything? I don’t want to plan things this way and then find out later that I can’t get hold of them…
The calculator has always been a bit quirky, so I hardly ever used it.
You can quickly work it out yourself to see if it’ll work.
The 450/100 and 200 are definitely still available.
If you add a second string and a few panels to it, it suggests the 450/100.
Connecting 10 modules to one tracker doesn’t make much sense either, because a tracker can handle a maximum of 3,000 W.
Two strings of 5 (or 6/4) would be better, so you can make full use of the power.
The MPPT RS 450/200, which was offered straight away in my configuration and also seems like a good fit, doesn’t appear to be available in the configurator at the moment.
But with 10 modules, you’re right at the upper voltage limit and above 8× the float voltage.
My guess: are they prioritising clearance sales of the 12 A trackers?
That’s a VERY vague statement, isn’t it?
There are also modules that you can easily connect 20 of in series to an MPPT 450/xxx.
It depends on the open-circuit voltage (VoC) of the modules used.
The VoC multiplied by the number of modules in series should be up to 20% below the MPPT’s maximum input voltage (depending on the minimum temperature expected).
If you don’t want to do the calculations yourself, there’s the MPPT calculator.
