There’s no problem voltage-wise. However, current-wise, it always throttles back to 198 A here. (The image was just a snapshot.)
Is there somewhere I can see in a graph how often the system throttles back and how much headroom there is? Then I could consider whether it might be worth splitting off a few panels and giving them their own MPPT.
You’ll have to test whether your modules would really produce more … for example, by disconnecting one string and seeing whether the others then deliver more.
How can east and west produce almost the same amount??
Thanks, it’s cloudy again now, but apparently the sun is supposed to come out again tomorrow.
I’ve created a switch in Home Assistant that turns on at 190 A and switches off again below 190 A, and I’ll use a statistics helper to track how many hours it’s on for.
That way, I have at least two areas I can check.
The only question is at what point a new MPPT would be worthwhile.
The cable won’t cost anything, just a new DC combiner box and MPPT
just for the “summer months”, when I already have too much PV power anyway.
The mppt is max 4000W per tracker, max 11500W overall - the limit determined by your battery voltage multiplied by a maximum of 200A at 25C.
Typically the recommendation is to over-panel by 30% so 15kWp.
All in the charger datasheet.
In my experience, here at least, we lose about a third of production. Cloud edge effect, not included.
Its never a good idea to run a charger above 75% for efficiency.
I would add another mppt.
I’ll give it a try tomorrow when the sun stays out for longer. Then I’ll disconnect two strings (east and west) and see how much more the other two produce.
And then I’ll probably order two more small MPPTs…
No need to do disconnect anything. Go to Advanced section and create a custom widget which contains PV power of all of your MPPTs. Unfortunately there has not been a clear day since I installed my system, but in this example you can see that L3 inverter (white line) starts producing later as solar panels connected to its MPPTs are pointing in South-West direction where L1 and L2 panels are facing South-East and are producing earlier in the morning.
If you evaluate data via Home Assistant over MQTT: There is the topic ././solarcharger/<geräte-id>/MppOperationMode as an integer value. With “0”, the MPPT is off; with “2”, it is operating at full power; and with “1”, its output is reduced.
With 11 kW of power achieved, you’re within the real-world range to be expected from 17 kWp (under optimal conditions, such as sunlight hitting at exactly 90 degrees). I don’t think another MPPT will be worthwhile.
