MPPT 150/35 connection to existing 3 phase system
Folks, I have to connect 3 panels to my systems that contain 3xMultiRS solar (each with its own array). I bought Smart Solar MPPT 150/35. It has VE.Direct port.
As far as I got from the Cerbo manual, I have to connect VE.Direct-to-VE.Direct. My question is the following: should I perform a detailed configuration of MPPT or Cerbo take care of it using BMS data?
It pays to always configure every charger. If something goes wrong, it has all the right settings.
Thank you! I mostly spoke about the kind of auto configuration. Got it, will configure everything manually.
It will be managed with DVCC so will inherit what it needs to know, manual config is a good practice. Just in case.
