Mppt 100v/50amp with wattcycle 314amp/h 12v is this acceptable?
So that’s the mppt and battery, I’ve 2 350w LG panels in serial, each panel with 42.4OV, I measure about 80 on the positive line. Will this work to charge the Wattcycle with its built in BMS?
The two solar panels in series are OK.
However, you should check the values in the MPPT to make sure that all settings for your LiFePo are correct.
I’m planning to use the Victron model. Is the Wattcyle LiFePo? Will this setup work with that Battery? I’m buying a battery and reworking my van system because my Blueitti failed…I’ve got everything downstream of the Battery well configured, I’m just looking for a superior Battery (w BMS is nice), MPPT to work well with my panels. I will of course follow the MPPT instructions for battery chemistry.
the WattCycle goes to sleep and is USELESS
