Mppt 100/50 intermittent charge
I have this installed in my mohome, i had it attached to my leisure battery and it worked fine.
I now have ot connected to my master volt battery protect, to charge both leisure and vehicle battery. But now it seems intermittent.
I know the battery protect means it does not see a voltage and I suspect this is the issue, although why it charges sometimes and not others does confuse me,
I think it charges okay with engine off, and does not with engine on when alternator voltage is on one of the master volt out terminals.
But that is difficult to say for certain as looking at history other days have low outputs.
Are there any settings that can make the charger charge even without it seeing voltage?
Can anyone ex-lain this intermittent charge/no charge?
If 9 have a logical reason the master volt has a voltage since pin for intelligent alternators, but it difficult to get master volt to tell me what it does so i would rather not use….
