MP2 5000 lights flicker in island mode
Hello Victron fans,
I have a problem with the lights throughout the house, which are on the same phase as my 3D printer. While it’s printing, the motors cause such severe load fluctuations that the lights flicker. It doesn’t even draw much power (between 50 and 300 W), but the load fluctuations don’t seem to agree with the MP.
Is there a way to fix this? I’m thinking of a device I could plug into the socket before the printer to smooth out the load fluctuations?
Thanks and regards,
Heiko
A typical phenomenon with these power supplies and this kind of load.
What supply voltage do you have at the servomotors and/or the power supply?
I don’t know, it’s an Anycubic Kobra S1; the power supply is internal.
On the AC side, that’s pretty difficult, because you can’t store anything here that’s readily available … On the DC side, after the power supply, you could fit a capacitor from the automotive sector quite nicely … they were always installed in the boot so that the vehicle’s electrical system voltage wouldn’t drop when the bass kicked in and the current got high.
The idea is good, Anycubic Netzteil - 3DJake Deutschland
24V, you could just hook a hefty capacitor up between V+ and V-. There are probably car audio power caps rated for up to 24V too; lorries often have 24V.
I would consider it uncommon to have flickering lights in a Victron powered installation.
Single and tri-phase systems I monitor have no such issues, despite the 500-2500W loads switched every second or so.
The 2500W loads do create a slight voltage drop but it is due to power distribution.
A 300-500 switching power supply should not, in normal circumstances, create any visible power network disturbance.
I would check all involved AC connections and power distribution panels.
Regarding the large capacitor on DC side, be aware that not all switching power supply accept it or it is up to a limit.
For curiosity, what kind of light fixtures/bulbs are installed, LED, fluorescent, incandescent, other ?
I think your options will be pretty limited for 24 V. But you can simply connect two inexpensive 12 V ones in series. Just make sure to “pre-charge” them before connecting the pair to the power supply. The question now, though, is what happens when the capacitor has discharged and you switch the system back on a few days later … you’d really need to incorporate a pre-charge circuit using a timer module as well …
What batteries are you using?
I’ve had a bit of a look around: power caps are too expensive, especially if they have charging electronics built in, so they’re out.
There are four Pytes V5s connected.
… then “fast current” shouldn’t be a problem … if it were still lead-flow or something … :thinking:
We have various lights and they all flicker: LED bulbs, 230 V halogen bulbs, low-voltage halogen bulbs, and the odd old incandescent bulb here and there. I’d rule out wiring problems. Firstly, the house is relatively new (built in 2006), and secondly, nothing flickers when running on mains power.
Strange, the Anycubic power supply in the picture says 24 V, 6.5 A, if I’m reading that right… That would only be 156 W.
These switch-mode power supplies are generally pretty nasty loads … especially when switching on or during load changes … even at low power, the whole thing behaves pretty much like yours because there’s no mains impedance … it just starts oscillating … when running on mains, the grid “supports” the load changes, and the Multi just passes it through.
I would try to go “upstream” on the AC network, starting from the socket and follow the repetitive voltage drop. There are multimeters or oscilloscopes that measure/visualise such drops, having at least 10-20 samples/second.
I’ll have to explain to my wife that she’ll have to put up with the lights flickering when I print stuff for her, like I’ve been doing all day today :slight_smile:
And the printer’s practically right next to the multi-socket extension leads in the utility room. There are two circuit breakers and 3 metres of cable in between, okay, plus a few terminals and the mains emergency changeover switch.
That wasn’t a problem with the sluggish Ender 3, but the Anycubic really zips along. Maybe I’ll try getting it to print more slowly.
… and if not for her … ??? … :sweat_smile: … then only during the day :expressionless_face:
Two capacitors don’t even cost €100 … you could give it a go for the sake of domestic harmony :innocent:
Why not just swap the phase … as an experiment for all of us here, too … let us know how it goes
99% of it’s down to the lack of a proper harmonic filter in the power supply, you get the exact same issue with cheap LED drivers. Your best bet is to install a decent mains filter.
I noticed it during the day today, because my child had the light on to study and it was really overcast. I did some investigating to find out what the problem was. I suspected the printer, so I switched phases and lo and behold, all the lights on the other phase were flickering. Anycubic cheapo stuff :slight_smile: Maybe I should’ve gone for Bambu after all.
Maybe I could install a better power supply? What do you mean with “mains filter”? Some device in the AC line or in the power supply?
Because you mention cheap LED drivers: I’ve read somewhere, that some PWM devices also cause those issues.
A line filter placed before the printer’s power supply unit.
Any form of switching-based conversion, if lacking high-quality filters, will cause this problem. You are interfering with the MP’s ability to correctly generate a sine wave.
