Hello, I’m using a 4 MP2 as a charger for the Pytes V5 battery. The MP2 is powered by a 5 kVA diesel generator with AVR regulation. The MP2 charges the Pytes for about 2 minutes and then shuts down for no apparent reason. In VEConfig, I’ve configured the MP2 for no grid, extended frequency range, dynamic current limiting, UPS disabled, and poor input voltage.
The input frequency is set to a maximum of 52.2 Hz, and the current is set to 13 A. That should be fine, but the MP2 still shuts down after about 1 to 3 minutes.
The system is a three-phase ESS setup and runs without any problems.
